Routing problems through Async interface
I'm successfully connecting two routers through a DDR configuration, however I need to pass dynamicaly two routes for networks that are directly connected to the Router that is starting the DDR connection. Although I configure in the Async interface: async dynamic routing, it doesn't work. Has anybody know what can I do.
Berlitz
Re: Routing problems through Async interface
Try "async default routing" under the async interface.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
According to some Cisco Doc I found, you should use "Async dynamic routing" command under the As interface. Unfortunately this does not work for multicast/broadcast based routing ptotocols. You can run BGP using this command, but not RIP or OSPF. The proper command as stated in the previous post is "async default routing." This will work for sure.
94
