Webcast-Catalyst9k
Routing problems with ADSL & 2610 router
I have up graded a 2610 router with 2 x ADSL Wic's.
When the router is configured the connection to the Internet opens & I can ping internet address from the router.
The PC connected (via crossed over cable) can ping the router ports (lan & wan) but not any Internet address.
See attached config.
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
000091 0X0008B800 C2600 single Ethernet
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X003903B0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 4Mb.
Using 6 percent iomem. [4Mb/64Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(11)T1, RELEASE SOFTWARE (fc2
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 29-Sep-02 21:46 by ccai
Image text-base: 0x8000809C, data-base: 0x8166E55C
cisco 2610 (MPC860) processor (revision 0x203) with 61440K/4096K bytes of memory
Processor board ID JAD04525MZ7 (2077339766)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 ATM network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Press RETURN to get started!
*Mar 1 00:00:19.467: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
*Mar 1 00:00:19.467: %LINK-3-UPDOWN: Interface ATM0/0, changed state to down
*Mar 1 00:00:19.467: %LINK-3-UPDOWN: Interface ATM0/1, changed state to down
*Mar 1 00:00:20.669: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/
*Mar 1 00:00:20.669: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, ch
anged state to down
*Mar 1 00:00:20.669: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/1, ch
anged state to down
*Mar 1 00:00:21.486: %ATM-5-UPDOWN: Changing VC 8/35 VC-state to PVC created.
*Mar 1 00:00:23.774: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 1 00:00:24.275: %LINK-5-CHANGED: Interface ATM0/1, changed state to admini
stratively down
*Mar 1 00:00:27.184: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:27.184: %SNMP-5-COLDSTART: SNMP agent on host Hjlyons.com is under
going a cold start
*Mar 1 00:00:28.189: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/
Hjlyons.com>
Hjlyons.com>
Hjlyons.com>en
Password:
Hjlyons.com#sh run
Building configuration...
Current configuration : 1310 bytes
version 12.2
hostname Router
xxxxxxx (moderator edit)
ip subnet-zero
ip name-server 159.134.237.6
ip name-server 159.134.248.17
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
voice call carrier capacity active
mta receive maximum-recipients 0
interface ATM0/0
no ip address
no atm ilmi-keepalive
pvc 8/35
pppoe-client dial-pool-number 1
bundle-enable
dsl operating-mode auto
interface Ethernet0/0
ip address 213.190.154.25 255.255.255.248
ip tcp adjust-mss 1452
half-duplex
interface ATM0/1
no ip address
shutdown
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname username
ppp chap password 0 password
ppp pap sent-username username password 0 password
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
dialer-list 1 protocol ip permit
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password password
login
end
Tony
1 ACCEPTED SOLUTION
Re: Routing problems with ADSL & 2610 router
Having already verified that your Internet connection is good with a ping from the router, the next step would be to do an extended ping from the Ethernet0/0 interface. My guess is that you can't. Your using a public IP address on the ethernet side, but your ISP may not be routing it to you.
You have two options if that's the case. If your IP addresses are actually registered with your ISP, get them to set up routing properly. If they are not actually registered, or you simply want to hide your LAN behind the router (prefered) you can set up PAT.
On the E0/0 - ip nat inside
ON THE Dialer1 - ip nat outside
from global config - access-list 1 permit 213.190.154.24 255.255.255.248
from global config - ip nat inside source list 1 interface Dialer1 overload
Tony, if you find what the problem might be, please let me know. I am running into the same exact problem with my setup. I have the identical setup, except with only one ADSL-WIC. I think you will find that if you do "NAT" on your Dialer interface, then everything will work ok. If you are like me and need to use a static IP address, then there is no access. Like you, I am able to ping addresses on the internet, but not able to get access through from my LAN. I worked with Cisco a bit on this and the engineer believed that my configuration is correct, and the problem might be with my local provider (BellSouth) not having my IP address assignments routed correctly. I have contacted Bellsouth, and am still waiting to here back from them. They usually aren't the fastest in getting a response back. If you discover anything, please let me know at David_Coleman@dayintl.com. If I find anything, I'll be sure to let you know.
Tony, I seemed to have resolved my problems with BellSouth. I happened across a small blurb on their support website about appending "%static" on my username for login. I called their tech support and confirmed. I made the change and everything seems to work as it should. I'm not sure what ISP you are using but you might check to make sure that your login is correct. BellSouth told me that until my login was correct, my ip addresses would not be available and routed for me to use. My username now looks like "username%static".
David,
My problem was not using nat, and i had the static ip addressing from the second account in use with wrong username & password.
Thank you for your help David & Bob.
Tony
Hello Tony,
I was just wondering how good your connection is with 2 ADSL lines? I noticed that you are using Eircom as am I. We just got connected with a 2621 and 1 ADSL line. I was disappointed with it (especially playing games online...clanradox ping is crap now)so I was considering going with another line through the same router. We are coming from a 512K IP line with Esat, and it seems a bit faster and infinetly more stable. Don't ask me why.
How many PC's do you have on your lan?
Tnks
Chris
Chris,
I'am setting this up for another company, the idea is one ADSL line for mail and the second one for Surfing etc. Eircom up to a couple of weeks a did not support multi-linking of ADSL lines. The speed issue is a result of the contention ratio, if you check it with http://www.modemspeedtest.com/ a couple of times during the day you will find big differences.
Tony
I was hoping that the connection would be faster than our 512K IP line. I'm still not sure why our IP line is actually faster than the 1MG ADSL line even with twice the PC's hooked up to the IP line. I'm still wondering if there is a configuration issue on my router possibly. Do you think that a multiple line might take care of the latency issue?
You might be experiencing a traffic contention issue with your ADSL provider.
Your local ADSL link does offer high speed access, but it connects to a local ADSL Mux, along with many other ADSL users.
The provider then gives a shared uplink for all users on the mux.
With leased line you have 100% of the bandwidth you pay for, so it can be faster.
This contention on ADSL can be 20:1 and higher........the hidden cost of cheaper bandwidth!
231
