Routing Protocol in Hub-Spoke network
What would be the best approach for HUB-SPOKE WAN network consisting
of one hub and 200 spoke endpoints out of the following approaches?
1.) fully static routes ?
2) Fully ospf ( with several areas )?
3.) static and ospf mix with redistribute ?
Any referance/ sample would be appreciated.
Bronze
Re: Routing Protocol in Hub-Spoke network
If you are using Cisco routers for all sites and you do not require disabling CDP, you might want to try using ODR:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca75f.html
using static routes would be an administrative overhead.
You can use either ospf or eigrp. I have seen networks running EIGRP over a 1500 remotes...Its pretty stable.
97
