Routing Question
Hello:
Apologies if this is a dumb question but I am just getting started with routers and have a rotuing question. Looked through several books and still not clear how to acomplish this. I guess I'm a bit confused with the relationship of the interfaces on each router. What I am trying to accomplish in a lab environment is this.
Router A -
Int Ethernet 0 - 10.0.1.111
Int FA0 - 10.0.3.1
Router B -
FA - 63.148.230.1
Ser0 - 63.148.228.x
I am trying to set up a route that would allow anything from the 10.0.3.x (lab) network to route out through router b. keeping the lab environment segregated. How do I set up the routes. Can't figure this out.
Thanks again.
1 REPLY
Bronze
Re: Routing Question
Without knowing more about the connectivity between these routers and the lab network, we can't provide an answer. If you're looking to tell router A to send all traffic sourced by 10.0.3.0/24 to router B, you probably want to use Policy Routing (you can search the site for configuration instructions). But this assumes there's a direct connection between the two routers, which doesn't appear to be the case based on the IP addressing you gave.
185
