Webcast-Catalyst9k
Routing question
Hi ,
We will be connection two core Layer switches 4948's into two 3662 routers. It has been requested to run EIGRP between the four devices , and putting all four in the same subnet on VLAN901. Will this load balance properly over the uplinks, as we were going to directly connect the core swithces , with the port set to an ip address and not running at layer2. Can someoone please point out why having all four interfaces in the same subnet and set on the interfaces as VLAN901 will be better.thanks
1 REPLY
Re: Routing question
Hope that the following will be useful for you:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
Leo
98
