Webcast-Catalyst9k
Routing to another gateway 3750
Hi there looking for some help
I have a Cisco Catalyst 3750 setup with multiple vlans with all traffic going through a PIX (Gatway A) IP route 0.0.0.0 255.255.255.255 10.10.10.1
There is a second Gateway/Firewall(B) 192.168.172.1 which we use for a couple of older systems, for dial in support we also route any traffic for these outside clients through this gateway using the IP route command
I have a PC in my office which I have assigned a static IP 192.168.172.10 what I want is for this PC to use the second Gateway (B) and not gateway A
So how do I get the switch to forward all traffic from particular IP address to the second gateway?
I also created a topic for this in WAN but I think its best in this forum, and I wasnt sure on how to move it
1 REPLY
Silver
Re: Routing to another gateway 3750
You can enable the policy-based routing to redirect the traffic which is belonging to 192.168.172.10 then redirect to the gateway B address as next-hop.
Check below for info.
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a00801f3b54.shtml
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75d2.html
Hope this helps.
105
