Community Member
routing token ring vlans on catalyst 5500
We have a catalyst 5500 with supervisor IIIG and RSFC (NOT RSM). We need to route TCP/IP traffic between ethernet and token ring VLANs on this switch. I see in the CCO documentation that the RSFC does not support token ring. Do we have to use an external router or RSM to route between the token ring and ethernet, or is there a version of code for the sup IIIG that supports this?
1 REPLY
Re: routing token ring vlans on catalyst 5500
You are correct. RSFC does not support Token ring. Software upgrade will not support it. You have to have an RSM in the switch or an external router
96
