Community Member
Routing using diginet and adsl links to one site
I have a customer who connects to the mpls network using a leased line and adsl both to the same site. The leased line use Cisco 1721 and the adsl use cisco 837 sitting in the same subnet. The problem is that both links can not be up at the same time. How can I get both to be up at the same time.
Silver
Re: Routing using diginet and adsl links to one site
The interface may be configured as backup and they may be used as secondary.
since both the links are getting connected to 2 different routers i would suggest to see something inline with HSRP for reduandcy.
do check this link out for more info ..
http://cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800b3e13.html#wp1001531
Also before enabling or getting on to the implementation stage do remember the ios code support for this particular feature in both of your routers and the reqd H/W resources like Memory and flash size required to support the ios code..
regds
Community Member
As per HSRP, is this not for router backup? where it detects a failed router and then allocates a standby? With regards to the original question, do you want the diginet and adsl line up simultaneously? Maybe load balance across to different routers?
Community Member
Yes, that is correct I want to load balance across the different routers.
Community Member
Well then i think Multichassis Multilink PPP would be your option. Check to see if your routers will support this option. Most of the 1000 series routers do, not sure about the 800s. Hope this helps.
Community Member
Community Member
Thank you very much!!!
Since you wanted to have both reduandcy as well as load sharing in addition to my earlier post to look out on HSRP i would add to check out for configuring different groups on the routers to check for load sharing with HSRP itself.
do refer this link for more info on load sharing with hsrp..
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800b3e13.html#wp1023868
regds
Community Member
255
