Webcast-Catalyst9k
Routing using port number
Is there a way to route an ip addresse based on which port the traffic is coming out of. Example; 192.168.0.100:80 to 10.0.0.100, 192.168.0.100:4032 to 10.0.0.101?
Bronze
Re: Routing using port number
Yes you can
first define extended access list to match your port numbers
for example:
ip access-list extended test
permit tcp/udp src dst eq port (applicable only on TCP/UDP protocols)
route-map test
match ip address test (name of the extended access list)
next apply that on the iface you want via ip policy route-map test
and you are ready to go :)
95
