routing vlanswith 2950 and 2621
I am currently trying to route vlan1 and vlan2 of a 2950 through a 2621. the 2950 is running ios 12.0(5.3)ws1 and the 2621 is running (c2600-js-m)12.1(9a).The native vlan on both devices is vlan1 and I'm using 802.1q, as that's the only encapsulation that the 2950 supports. The subinterfaces of fe0/0 for the 2621 sh up up, the same holds true for fe0/25 of the 2950. when I do "show cdp nei" I can see the other end.
I can also do a directed ping from one sub-interface to the other, on the 2621. I can not how ever ping across. Am I missing something?
Re: routing vlanswith 2950 and 2621
Can you paste the interface configuration from both the 2950 and the 2621? Also refer to the following page to see if your configuration is correct
http://www.cisco.com/warp/public/473/43.html
Here is the config of both devices.
4 ISDN Basic Rate interface(s)
--More--
unix_test01#sh run
Building configuration...
Current configuration : 1063 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname unix_test01
enable secret 5 $1$ERUa$8zwFpm3GyrQHGpBri6wlp/
ip subnet-zero
--More-- interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
encapsulation dot1Q 1
ip address 147.141.5.250 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 147.141.6.250 255.255.255.0
interface Serial0/0
no ip address
shutdown
no fair-queue
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
--More-- !
interface BRI1/0
no ip address
shutdown
isdn x25 static-tei 0
interface BRI1/1
no ip address
shutdown
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
ip classless
ip http server
--More-- !
line con 0
exec-timeout 0 0
password frame
login
line aux 0
password frame
login
line vty 0 4
password frame
login
no scheduler allocate
end
unix_test01#
sh run
Current configuration:
version 12.0
no service pad
hostname sw2ip33_test
enable secret 5 $1$NCzP$lpY.4UTeOAleCcUtBz1qv.
ip subnet-zero
--More-- !
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
--More-- interface FastEthernet0/13
switchport access vlan 2
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
--More-- !
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
switchport mode trunk
interface FastEthernet0/26
interface VLAN1
ip address 147.141.5.240 255.255.255.0
no ip directed-broadcast
no ip route-cache
--More-- ip default-gateway 147.141.5.250
line con 0
password frame
login
transport input none
stopbits 1
line vty 0 4
password frame
login
line vty 5 15
password frame
login
end
sw2ip33_test#
Thanx
LB
Try using "native" keyword
encapsulation dot1Q 1 native <<<<<<<<--------
My bad..I pointed you to a wrong URL earlier
http://www.cisco.com/warp/public/473/50.shtml
When I enter fastethernet 0/0.1 and specify dot1q, it doesn't have the option for "native". just CR>
I beleive I have corrected the problem, albeit, not the way I would have thought. I decided to configure the 2621 fastethernet0/0 the same way you would if I were using ios earlier than 12.1(3)t. I removed sub interface fastethernet 0/0.1 and gave the IP address to fastethernet 0/0. I can now reach both vlans on the 1950. There appears to be a problem using this config with 12.1(9a).
Thanx for the help.
91
