Routing woes (Help)
Hi Guys looking for some help here.
I have a 2600 with 2 Ethernet ports in with each interface on a different IP network, Eth 0/0 172.19.128.0 255.255.252.0 and Eth0/1 192.168.1.2 255.255.255.240. What I am trying to do is to route the traffic from one network out over the other and then out through a firewall.
So far I have configured the router to a position where I can ping external IP addresses from the Eth0/1 interface but not from the Eth0/0.
Please see my config below for details.
Eth0/0 172.19.128.54
Eth0/1 192.168.1.2
Firewall 192.168.1.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname DR-NAT-Router
logging rate-limit console 10 except errors
enable secret 5 *****************************
ip subnet-zero
no ip finger
ip domain-name europe.tel.com
ip name-server 172.19.130.31
ip name-server 194.72.6.57
ip name-server 194.73.82.242
call rsvp-sync
interface Ethernet0/0
ip address 172.19.128.54 255.255.252.0
ip helper-address 172.19.130.31
full-duplex
interface BRI0/0
no ip address
shutdown
interface Ethernet0/1
ip address 192.168.1.2 255.255.255.240
half-duplex
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
dial-peer cor custom
Thanks for taking the time to look at my problem.
  • Other Network Infrastructure Subjects
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: Routing woes (Help)
Yes, you can. But the firewall will then NAT once again. Not an optimal configuration.
However, if you want to proceed with this approach, here is a sample config
ip nat inside
full-duplex
half-duplex
ip nat outside
ip nat source list 1 interface e0/1 overload
access-list 1 permit 172.19.128.0 0.0.3.255
Please rate helpful posts.
1) The firewall needs to have a route back to 172.19.128.0/22 pointing to default gateway 192.168.1.2/28
2) In order to ping external addresses from the 172.19.128.0/22 network, you need to create a NAT for that network on the firewall as well.
Thanks for your reply.
Would it be possible to setup NAT on the router as I really dont want to start changing the firewall settings?
Yes, you can setup NAT on the router but the router must hold the external (internet) IP.
So is it not possible to NAT from the 172.19.128.0 network through the 192.168.1.2 address?
ip nat inside
full-duplex
half-duplex
ip nat outside
101
