RPS 675 UK AC Power Cord
We have recently moved office and our RPS 675's have ended up connected with an AC power cord with a 5A fuse. The unit itself is rated at 10-6A so I'm thinking the power cords have been mixed up and should have a higher rated cable (like 10Amp). Unfortunately tech specs and packing list of this product only list as "AC power cord" can anyone check/confirm ?
Re: RPS 675 UK AC Power Cord
find the details below.
AC input voltage
100 to 240 VAC (autoranging)
6 to 10 A, 50 to 60 Hz
875 W
Silver
For standard UK plug, it should able to support 13A. So if you prepare a standard one w/ fuse, there should be no problem. However, if you order the equipment and selected power option, it will come w/ the correct power cord. Don't worry.
Hope this helps.
144
