RSPAN problems with Cat3550 and 2950
I'm trying to initiate an RSPAN session with a 2950 as a source switch and 3550 as a destination switch with a 2950 intermidiate switch, and I can't monitor nothing.
If I configure the intermidiate switch as the source switch and there's direct connection with 3550 it works properly, so I think that the problem is that the intermidiate switch don't switches RSPAN information to the 3550. What can I do if I want to monitor with this intermidiate switch?
Thank you!
1 REPLY
VIP Purple
Re: RSPAN problems with Cat3550 and 2950
have you configured the RSPAN VLAN on the intermediate switch ?
Can you check if you followed the guidelines for setting up RSPAN across different switches at the link below, or post the configs of your three switches ?
http://www.cisco.com/en/US/partner/products/hw/switches/ps5206/products_configuration_guide_chapter09186a00801ce1b3.html#1081130
Georg
107
