RSPAN with Cat2950 Switches
Good day,
I'm trying to create a RSPAN session with 2 Catalyst 2950 switches but it doesn't work (no packets shown by the network analyzer).
I don't know what I'm doing wrong. Does anybody see any mistake in my configuration?
- all ports in VLAN 1, except of Fa0/48 (Trunk to neighbor device)
Switch 1:
vlan 99
name Monitor-VLAN
remote-span
interface FastEthernet0/24
description switch-2 Fa 0/48
switchport mode trunk
switchport nonegotiate
monitor session 1 source interface Fa0/1 rx
! Notebook for testing connected to Fa0/1
monitor session 1 destination remote vlan 99 reflector-port Fa0/23
Switch 2:
vlan 99
name Monitor-VLAN
remote-span
description switch-1 Fa 0/48
monitor session 1 destination interface Fa0/1
! NW-Analyzer connected to Fa0/1
monitor session 1 source remote vlan 99
Rolf
Re: RSPAN with Cat2950 Switches
Rolf,
Could you please let me know how many trunk links are used between the switches..
You said Fa0/48 is the trunk link but your config suggests you are using fa 0/24 for trunk link as well.
Also..Do you have any other switch linke 3550,3560 that you can use as an intermediate switch for RSPAN.
What do you see in your Show vlan. Paste the output under vlan 99.
regards,
-amit singh
Thank you for the quick response.
You're right - the trunks are not on Fa0/48 (both switches have only 24 ports) but on Fa0/24.
It's just a test with only those 2 switches, connected to each other (only) via Fa0/24.
Here is the output of the show vlan command:
Switch#s vlan id 99
VLAN Name Status Ports
99 Monitor-VLAN active Fa0/24
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
99 enet 100099 1500 - - - - - 0 0
Remote SPAN VLAN
Enabled
Primary Secondary Type Ports
Rolf
Well, Rolf the configuration is ablsoutely fine and seems to be a hardware limitaion only.
Please make sure that you dont have any other SPAN or RSAPN session configured on either of the switch. I see that you are montiroing the traffic only in one direction which doesnot apply to the RSPAN limitaion either.
Please let me know the IOS version you are using. Paste an output of show version.
regards,
-amit singh
Amit,
sorry - I didn’t see your response yesterday.
Here’s the output of show version:
Switch#s vers
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA4a, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 16-Sep-05 10:46 by yenanh
Image text-base: 0x80010000, data-base: 0x80562000
ROM: Bootstrap program is C2950 boot loader
Switch uptime is 45 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA4a.bin"
cisco WS-C2950-24 (RC32300) processor (revision R0) with 21039K bytes of memory.
Processor board ID xxxxx
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: xxxx
Motherboard assembly number: xxxx
Power supply part number: xxxx
Motherboard serial number: xxxx
Power supply serial number: xxxx
Model revision number: R0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: xxxx
Configuration register is 0xF
I studied the ‘Configuring SPAN and RSPAN’ (Chapter 21 of Catalyst 2950 Desktop Switch Configuration Guide) again and found as a Configuration Guideline:
..., you must have EI installed on your switch.
I wonder what ‘EI’ means?
Rolf
Hello Rolf,
have you found a solution ?
I have got exactly the same problem.
I insert a new question, why have you inserted the fa0/23 for reflector port ?
best regards.
Unfortunately I didn't find a solution with my test equipment but I tried the same configuration with a Cat4006 and a Cat3550 in our productive Network and it works fine.
I think it's a platform issue. And unfortunately I still don't know what 'EI' means. Maybe enhanced image? Doesn't sound plausible but I've no better idea.
You are rite in pointing out EI as Enhanced Image would suggest to check this link for more info on that.
http://cisco.com/en/US/products/hw/switches/ps628/products_data_sheet09186a00801cfb64.html
regds
165
