Community Member
RSPs PC Flash Cards
Hi, can the PCMCIA flash memory cards that come with the RSPs be use from a PC? In the label of the card, it says i can insert it in my computer, so, can i format, copying images from my PC to the flash card? thanks ahead for your comments.
1 REPLY
Bronze
Re: RSPs PC Flash Cards
I don't think that's possible. If you want to use the PCMCIA on a router, it needs to be formated on a similar router with a similar file system. In order to boot a router from a PCMCIA card, the card must have been formatted on a similar system.
Check out this document, and it has all that you need to know about PCMCIA cards:
http://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a00800a7515.shtml
90
