Community Member
Run out of system memory, screen scrolling disabled
Dear all,
Has anyone seen the follow message appear on their Cat6509 before?
"Run out of system memory, screen scrolling disabled."
This 'error' has started since an as yet unexplained UDLD event occurred earlier today. Everything else appears to working as normal.
Any ideas?
Thanks in advance,
Colin Finn
Re: Run out of system memory, screen scrolling disabled
Looks like you are hitting the following memory leak bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdu25416
Resetting the switch should fix the problem for now, but I suggest that you upgrade CAT OS to avoid this bug in the future
Community Member
Thanks, but the CatOS I'm using already has that bug fixed!
Colin
What software version are you running? Can you paste the output of sh ver
111
