Running a server inside a NAT'd System
I am Using BadBlue to run a peer to peer server inside a LAN that is NAT'd
I need to know how to tell the router to do port forwarding to my ip. It works fine inside the LAN but external remote machines cant get through to my NAT'd ip.
I am using cisco ubr900 router.
Re: Running a server inside a NAT'd System
UBR900 is like any type of router so any type of nat configuration will work however you might want to look at
http://www.cisco.com/warp/public/109/config_nat_on_cm.html
==DMT>
how can i access the router to configure it?
103
