Runt Errors on EtherChannel (fibre) on a Cat6509 - Cat6509 link
We have a pair of cat6509 switches connected together via fibre (ZX GBIC) Gigabit links. Gig port 1/1 & 1/2 on sw01 (6509)
is connected to Gig port 1/1 & 1/2 on sw02 (6509). They are Dot1Q trunked and Etherchannelled.
Sw01 config:
module 1 : 2-port 1000BaseX Supervisor
set port name 1/1 xxx-xxx-SW-02 1/1
set port name 1/2 xxx-xxx-SW-02 1/2
set udld aggressive-mode enable 1/1-2
clear trunk 1/1 11-15,17
set trunk 1/1 on dot1q 1-10,16,18-1005,1025-4094
clear trunk 1/2 11-15,17
set trunk 1/2 on dot1q 1-10,16,18-1005,1025-4094
set port qos 1/1-2 trust trust-dscp
set port channel 1/1-2 mode on
end
Sw02 config:
set module name 1
set port name 1/1 xxx-xxx-SW-01 1/1
set port name 1/2 xxx-xxx-SW-01 1/2
clear trunk 1/1 11-14,16,18
set trunk 1/1 on dot1q 1-10,15,17,19-1005,1025-4094
clear trunk 1/2 11-14,16,18
set trunk 1/2 on dot1q 1-10,15,17,19-1005,1025-4094
end
As can be seen by the output below we are experiencing incrementing runt errors on Sw01 only on Gig port 1/1 (Gig port on WS-X6K-SUP1A-2GE). No errors are seen on
Gig port 1/2 of sW01 or on gig ports 1/1 & 1/2 of sw02.
So far we have upgraded swapped both ZX GBICs on Sw01. Each time one of the Gig ports was taken down to carry out a swap out of the ZX GBIC,
network connectivity was maintained as the traffic was forced to traverse the remaining link in the Etherchannel. When the previoulsy
erroring port (runts) was brought back up and checked for errors, the port would be found to be error free. But when the second Gig port (previously error free) in the Etherchannel was
checked for errors it was now found to be experiencing runt errors. This behaviour has been found to consistent when disabling and renabling a port in the Etherchannel. i.e. the runt errors
move to the other Gig port.
So far we have swapped both ZX GBICs in Sw01, the Supervisor module and MSFC2 card but the runt errors remain. We will be checking the fibre later today and swapping the ZX GBICs on Sw02
although I beleive the symptoms and migratory nature and behaviour of the runt errors as described above would seem to indicate more of a software issue.
Does anyone have any ideas or experienced a similar fault. Any help would be greatly appreciated.
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
1/1 0 0 0 0 0 2911
Port Last-Time-Cleared
1/1 Sat Jun 24 2006, 04:11:43
1/2 0 0 0 0 0 0
1/2 Sat Jun 24 2006, 04:11:43
Anonymous
N/A
Re: Runt Errors on EtherChannel (fibre) on a Cat6509 - Cat6509 l
U have cleared the vlans differently on the switches.see that u clear the same vlans at both the ends.
Try to specify the same set of vlans that need to be cleared.
Mahmood
What is the version of code? show ver and a show mod would be good, I think I remember a bug with some gig ports.
229
