Same IP Address leased from IP Pool
I got RAS (C3725 PRI Bundle) and 1 E1 PRI Link.
30 IP Addresses leased for Client access dial-in. But the same IP Address was leased to different Client in the same time and make confusion on Routing Table. Are there any comments on this events?
Thank you in advance for your help...
Amnuay
Re: Same IP Address leased from IP Pool
are the clients using same username & password by any chance?
Bronze
This can happen if the user's are loggin in with the same username and password, to get rid of the problem add the command "ppp ipcp username-unique" to your interface terminating PPP.
Daniel
Bronze
Its "ppp ipcp username unique" sorry there is no dash.
Daniel
87
