Saving running configuration on 4006
This is probably very basic, but I haven't done it before on this type of router.
Catalyst 4006 Router
IOS 7.3(1)
Please let me know how to save configuration changes made to the memory so that they take affect even after a reset.
1 ACCEPTED SOLUTION
Bronze
Re: Saving running configuration on 4006
To my knowledge, the 4006 is a catalyst switch that runs on CATOS. Assuming that your bootvar and config register are configured correctly, every change made is sent to NVRAM and will be available after reset.
HTH,
Ryan
Bronze
HTH,
Ryan
Try "write memory" or "copy run start"
By default, the config is saved to NVRAM every time you execute a command. However, there is an option to change the config mode to text. If this is changed as such, then you need to do a "write mem" as you would on a router.
So assuming you have not made such a change, you don't need to do anything to save the config.
HTH,
Bobby
*Please rate helpful posts
288
