Saving Switch Configurations for a later use
Recently I contacted an authoritative source regarding saving cisco catalyst 3550 switch configurations for a later use. The reason for doing this would be to replace a failed switch with its saved configurations. To do this we need to copy config.txt and vlan.dat separately to the new switch. I was wondering whether this all be combined into one running config file and upload to the switch for ease of use. Any insight would be greatly appreciated. Thanks.
  • Other Network Infrastructure Subjects
Re: Saving Switch Configurations for a later use
If VTP mode is transparent, the VLAN info are also saved in the switch running
configuration file and you can just back up your run/start-up config
http://cio.cisco.com/univercd/cc/td/doc/product/lan/c3550/12111ea1/3550scg/swvlan.htm#xtocid10
We are running VTP mode transparent. Excellent response. Thanks.
Please make sure you are running 12.1.9 and above to do this
86
