ten
Community Member
Scan a range of addresses
Is there an easy way to use a router to ping or scan a subnet to see what IP's are currently active.
Community Member
Re: Scan a range of addresses
you can try to ping the broadcast address of the subnet... the broadcast address is the last address of the subnet. You should receive a answer from the ip's which are in use. But.... not all devices are answering to directed broadcast
Community Member
Hi Ten,
I use a simple extended ping to the broadcast address, one packet 40 bytes. I think 36 bytes is the minimum.
Joe
116
