Community Member
secondary interface
HI ALL!
why & where we use secondary ip address in the same interface.
int f0/0
ip address x.x.x.x x.x.x.x secondary
ip address y.y.y.y y.y.y.y
10xs
Re: secondary interface
HI
One reason i can think of is that if u had segmented u r LAN in two networks or subnets so to communicate between them u can use secondry address on u r router.And if u r in a process of IP Address migration u can use secondry address.
Mahmood
Mahmood
Community Member
HI!
10xs for ur reply
Ali
ali you can also you secondary ip address when you are going to migrate form one protocol to other...and also in ip address migration...
hope this will hleps
regards
Devang
Just to add on do remember that neither eigrp nor ospf forms adjacencies with the secondary ip address.
it will create neighbors only with the primary ip address space..
regds
338
