Webcast-Catalyst9k
secondary ip addressess and HSRP
I have a quick question regarding HSRP support for secondary ip addresses.
Do I :
a) use an arp entry to fool HSRP
arp 45.127.72.130 0000.0c07.04
interface FastEthernet0/1
ip address 45.127.72.132 255.255.255.128 secondary
ip address 192.168.150.41 255.255.255.0
standby 3 priority 120
standby 3 preempt
standby 3 ip 192.168.150.1
standby 3 timers 5 15
standby 4 priority 120
standby 4 preempt
standby 4 ip 45.127.72.130
standby 4 timers 5 15
and/or use it with the secondary keyword after standby ip 45.127.72.130 ?
cisco IOS 12.2.8T
Silver
Re: secondary ip addressess and HSRP
Hi Eric. When you use standby with number (standby 4 ...) the number you chose is used to map to a arp entry. So you don't need to specify a arp manually.
Thanks. I must have read an old doc on HSRP
Secondary keyword has been supported for a long time on HSRP groups. Shouldn't need an ARP entries.
Also make sure you need 12.2.8T. That is that you have new hardware that requires it, or need newer features in it. Otherwise, 12.2(10a) mainline is the better choice. Remember T train gets all the new features, and sometimes new bugs :-)
112
