secondary ip and ISDN
1. I have a cisco isdn-router with primary-ip: PA and secondary-ip: PB configured for its ethertnet0.
2. I should configure the BRI0 as "ip address unnumbered ethernet0", (no transitnet?).
Question:
How can I configure the bri0 (dialer map or dialer profile) to two remote-site, when remoteA should use PA and remoteB PB as routeaddress ?
(Problem: by isdn callingout(unnumbered ether0) can ciscorouter only use its primaryaddress?
Can you give me a sampleconfig.
1 REPLY
Anonymous
N/A
Re: secondary ip and ISDN
You can only use ip addreess unnumbered on the primary address of any
interface.
If your scenario requires you to have two different address
then creat two loopback interfaces with two address and
use ip address lo 0 for dialer 0 and ip address lo 1 for dialer 1
I dont see problem dialing the two site with the same interface
address being used for unnumbered interfaces.
http://www.cisco.com/warp/public/701/20.html
95
