Selecting a multiservice/routing switches
I have got a requirement for a multiservice or routing switch. Im pasting it along with this meeage.Can anyone suggest me which switch touse and what all modules.
Thanks in advance
(MULTI SERVICE / ROUTING SWITCHES)
Interfaces to be supported:
100basetx fast Ethernet
Channelized E1 with g.703 coax interface
Serial port (x.21 ,v .35) for video
6 analog voice ports(FXS/FXO/E&M )
1 digital voice E1 port
The switch should have extension modules capability for optional addition of Ethernet or WAN interfaces
Frame relay
FRF 3.1 Multiprotocol encapsulation FRF 9 data compression for frame relay
Voice:
Must support voice over IP, voice over frame relay with:
CS-ACELp 8 kbps voice compression (g.729 and g729a) tandem voice switching silence suppression
Voice activity detection
Support for t.30 group 3 fax integrated echo cancellation
Integrated fax/modem detection
Protocol support:
TCP/IP suite
RIP1, RIP2, OSPF
VRRP
Point-to-point (PPP), HDLC multi link PPP
The switch should support load sharing on the WAN links
Quality of service support:
Layer 2/3/4 defined traffic flows capability
Qos should be supported on the MAN/WAN interfaces
Management requirements:
telnet
SNMP v1, SNMPv2
The software Managements for the ' switch should integrate with well known network Managements
platform (please identify in the remarks)
Out of band option
Rich logging feature internally with in the switch
Rich debug and diagnostic tools syslog server logging
RMON
RMON2
SNMP MIB II
Security options
Support for am
Support for RADIUS
Support for TACACS/TACACS+
Denial of service (dos) protection from TCP syn attacks and smurf
Minimum two level of access to the switch
Video:
Clear channel nx64k
Support for x.21 based video channel
Each remote site should have the following interfaces on delivery:
1 x 100 base tx Ethernet port --'- 2 x E1 g703 coax 75 ohms
1 x serial port (x.21 , v.35) for video
1 x e 1 voice module
1 REPLY
Re: Selecting a multiservice/routing switches
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources at the online http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
98
