Community Member
Selecting Cisco Router ...Help
I have a customer that wants to connect two offices 100 miles apart, 50 users at each site, what Cisco product should I suggest, and what circuit would handle the bandwidth requirements? DSL, T1, what kind of router.
1 REPLY
VIP Purple
Re: Selecting Cisco Router ...Help
I would look at either a 1700 (such as a 1720) or 2600 (such as a 2610) series router.
The selection of circuit is difficult to answer, since we neither know your requirements, nor what your local DSL providers are like.
The safe option would be to use something like a frame relay circuit. You'll need a WIC-1T card for the router should you go this way.
172
