06-25-2002 06:09 AM - edited 03-01-2019 10:33 PM
I have three pri's connected to my 3662. All three pri's are associated with the same number by BT. At the moment when a dial is instigated each pri is used in turn. I want to know how to configure the router so that only the first two pris are used for dialout (dialin to remain constant) then use the last pri if only the first two are full up. This is a temporary fix for some telco moves we are going to perform.
some of the current config:-
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-30
controller E1 1/1
shutdown
framing NO-CRC4
controller E1 2/0
framing NO-CRC4
controller E1 2/1
framing NO-CRC4
interface Serial1/0:15
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-net5
isdn incoming-voice modem
isdn send-alerting
no peer default ip address
no cdp enable
ppp authentication pap chap callin user
ppp multilink
interface Serial1/1:15
no ip address
encapsulation ppp
isdn send-alerting
no cdp enable
ppp multilink
interface Serial2/0:15
no ip address
encapsulation ppp
isdn send-alerting
no cdp enable
ppp multilink
interface Serial2/1:15
no ip address
encapsulation ppp
isdn send-alerting
no cdp enable
ppp multilink
interface Group-Async1
ip unnumbered FastEthernet0/0
ip access-group 102 in
ip helper-address 169.136.140.211
ip helper-address 169.136.140.56
encapsulation ppp
ip tcp header-compression passive
no ip mroute-cache
dialer in-band
dialer idle-timeout 600
dialer wait-for-carrier-time 20
dialer-group 1
async dynamic routing
async mode interactive
peer default ip address pool pool1
no ppp lcp fast-start
ppp callback accept
group-range 97 222
interface Dialer1
ip access-group 104 in
encapsulation ppp
dialer pool 1
dialer remote-name one
dialer string xxxxxxxxxx
dialer-group 1
peer default ip address 1.1.1.2
no cdp enable
ppp multilink
interface Dialer2
description Connection to MCI
ip address 170.127.85.211 255.255.255.192
ip nat outside
encapsulation ppp
dialer pool 1
dialer remote-name xxxxxxx
dialer-group 2
no cdp enable
ppp authentication chap user
ppp multilink
Does anyone know how to do this?
Thanks in anticipation...
06-25-2002 08:40 AM
Assumming that you want to dialout using modems from 3662...You can dedicate certain T1 lines to be used for dialout..using "modem dialout-controller" command..Here is the place which discuss that in detail
http://www.cisco.com/warp/public/471/modemdialoutcontroller.html
06-25-2002 08:47 AM
On the 36xx platform 12.2(10.2)T upwards or 12.2(10.3)PI05 upwards supports the "modem dialout controller" command.
Interseting though only one controller can be configured under a group of modem lines.
conf t
line 1 48
modem dialout controller e1 0
modem dialout controller e1 1<====will over write the e1 0
If the lines are divided, say
line 1 24
line 25 48
Not sure if this will suit your setup.
Thanks, Mak.
