serial int on 7206 problem
hi,
Can any one tell me Y is the status of DSR=down.when as i am able to ping the ip of the other end ip sucessfully.(DCD=up DSR=down DTR=up RTS=up CTS=up).
Router # sh int s3/2
Serial3/2 is up, line protocol is up
Hardware is M8T-V.35
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation FRAME-RELAY, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
LMI enq sent 1329, LMI stat recvd 1330, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 1023 LMI type is CISCO frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 77/0, interface broadcasts 0
Last input 00:00:03, output 00:00:03, output hang never
Last clearing of "show interface" counters 03:41:33
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
1425 packets input, 27700 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1505 packets output, 50632 bytes, 0 underruns
0 carrier transitions DCD=up DSR=down DTR=up RTS=up CTS=up
thanks
1 REPLY
Silver
Re: serial int on 7206 problem
DSR is assrted by the DCE, most likely the CSU the absence on DSR is not anything to be alarmed about. It generally means that the DCE is powered on. Since you can ping over the circuit then I would not sweat it.
88
