Serial interface controller residual bit errors
admin_2
Level 3
Level 3
We have an x21 serial interface connecting to a bpx frame-relay node.
The serial interface is amassing input and crc errors quite dramatically but we also notice that
on issuing command
#sh controller serial 0
the following output.
10241736 residual bit errors
(which is also incrementing)
Is this indicative of a card failure ??
Not applicable
It can be a defective connector, cable or backcard problem, try to isolate the problem by replacing each component one-by-one. Make sure the cable lenght is under X.21 physical specifications.
