Webcast-Catalyst9k
serial interface debug command
Is there a debug command for a router serial interface that will display on a console when the link goes down?
Bronze
Re: serial interface debug command
There is a command enabled by default on all interfaces, "logging event link-status" which will cause a message to be printed whenever the interface goes up or down. Again, this should be on by default for serial interfaces and you should be able to readily test this.
When I have a subinterface go down, it does not get logged. I can't find the command that you reference.
Enter the 'logging event subif-link-status'-command in your interface. That is not in your sub-interface.
Good luck
Edwin van Wijk
285
