Serial IP addressing with 2 routers and HSRP
I have 2 routers that have HSRP running on the Ethernet side, I would like to know if I can VLSM a C class address and use the smaller networks on the serial ports of both routers. Will this cause an issue with non-continues networks?
1 REPLY
Silver
Re: Serial IP addressing with 2 routers and HSRP
as long as they are on the same subnet and you are using routing protocols that support VLCM you should have no issues
92
