Webcast-Catalyst9k
serial link problems over microwave
I have several remote sites connected via microwave links. There is an ongoing ‘battle’ within my group that provides the routers, and the telecomms group that provides the microwave link, as to the cause of intermittent link problems we seem to be having. In the case of today, the error log on routers on both sides of the link report %LINEPROTO-5-UPDOWN constantly.
A show int on the interface on one side of the link shows
Serial1/0 is up, line protocol is down
Hardware is M4T
Description: 384k Link to TZRD08 Kulsary CC
Internet address is (removed)
MTU 1500 bytes, BW 384 Kbit, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Last input 00:13:06, output 00:00:07, output hang never
Last clearing of "show interface" counters 19:58:08
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
222083 packets input, 128854301 bytes, 0 no buffer
Received 0 broadcasts, 940 runts, 68 giants, 0 throttles
7622509 input errors, 4796745 CRC, 0 frame, 1271547 overrun, 365 ignored, 1554217 abort
206874 packets output, 91609712 bytes, 0 underruns
0 output errors, 0 collisions, 100 interface resets
100 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
The stats are from over a several week period, so I wouldn’t necessarily read too much into the high errors crcs etc, but there again it might be a symptom of the problem.
So is it a bad interface on a router, or is it the microwave link? How do I go about finding out?
The remote side is an hour’s drive away on bad roads so I’d prefer not to have to go on the road.
Raff.
Re: serial link problems over microwave
Based on my own experience I would investigate the link.
Arguments:
- The ratio between good packets and error packets is very bad
- There are 100 interface resets. This is most likely saused by carrier loss
- At the time of the sh int, the link was down
My conclusion is that you have a bad link. The high error ratio is due to clocking errors. This type of problem could be wheater-related
For example: fog > bad link; clear skies > it works
You can also experience problems around sunrise and/or sunset.
Thanks for your reply, I have seen fog cause problems. We've got blue skies at the minute, and this problem has been going on for about 24 hours now. It's -15C and has gone down to -24 recently though...
Do you know why there can be problems at sunsise and sunset?
126
