serial to analog modem cable
Can I attach an analog modem to serial interface on 1601?
(Router)------------(Analog modem)
Router 1601(1 Serial Wic)
Re: serial to analog modem cable
Are u planning to dial out or dial in ?
You can connect, if the serial wic is a sync/async interface. If yes, then you can change the mode from sync to async using, "physical-layer async" interface. After that, a db-60 to db-25 cable can be used to connect to an analog modem.
yaa i got it
thanks
manish young
Mostly you may have WIC-1T which dosen't supports Async communication pon it. Here is the link which describes the WICs and its capability with platform support.
http://www.cisco.com/warp/customer/107/hw_as.shtml
91
