Serial to Serial connection
I have to connect serial to serial between 2 Cisco router: Cisco 1600 series & Cisco 1005 respectively, with all IP configured. But they can't seems to connected, nor ping to one another.
I know something must be configure when Serial to Serial connection is used.
Anyone can advise me on that?
Thanks.
Re: Serial to Serial connection
What's your (wide area network) protocol encapsulation? i.e. Are you using HDLC, SDLC, ATM, Frame?
Can you see the routers' CDP neighbors? Are you serial up/up? When you try to ping, do you get "unreachables?" Or "no response?"
I will assume that the routers are connected back to back with no modem or CSU via one DTE and one DCE cable ?
If this is the case then you have to configure the DCE interface to provide the clock. This is an interface configuration command:
config term
interface Serial0
clock rate ?
where ? is one of the following clockrates :
1200
2400
4800
9600
19200
38400
56000
64000
72000
125000
148000
250000
500000
800000
1000000
1300000
2000000
4000000
Note that RS232 will only run up to 500k I think and that V.35 can run faster - I am unsure of the limits but there is a physical limit of the electronics in the serial interface for either type of serial applique.
I hope that's what you were looking for ?
288
