Community Member
Setting 3550 and 3560 Switched to Non-Negotiate
On some of the older models of the 3550 switches I was able to set the SFP interface to non-negotiate. I do not notice that command available in the documentation anymore. Does it still exist?
1 ACCEPTED SOLUTION
Community Member
Re: Setting 3550 and 3560 Switched to Non-Negotiate
Do you have access to any of the switches in question? You can always use the context help under the interface
(config-if)#switchport ?
On my 3550 the nonegotiate is an option.
James
1 REPLY
Community Member
James
164
