setting async mode interactive doesn`t work with AS2509 ?
when users with there IP address pre-configured on thier remote PCs, dial into my AS2509, with the following commands configured on the async interface:
[async mode interactive]
[async dynamic address]
the server refuse to the PPP connection initiation.
mean while it is now configured on the AS2509 async interface: [async mode dedicated], with there ip address obtained from a local pool .(with the dialup connection properties on the remote pc configured to: server assigns ip address ) and this cenario is working fine.
how do i configure the AS2509 to detect if the user is already have his IP address to login, and in the same time if he was not having an ip address, to let the AS2509 assign him an IP address ?
1 REPLY
Anonymous
N/A
Re: setting async mode interactive doesn`t work with AS2509 ?
With "async mode interactive" and
"autoselect ppp", "autoselect during-
login" configured under the lines, if
the remote PPP peers dials in and starts
sending PPP packets we should detect
this and start the PPP process on that
line.
As for the IP address, if the remote
requests an address of 0.0.0.0 we should
always retrieve an address from the pool.
If the remote requests a specific address
(that is not in the pool already), then
you may have to configure DDR (a dialer
map with that remote name and the static
IP address that the remote has) to get
this to work. Depending on whether you
have AAA enabled (for authentication and
authorization), if you continue to have
problems you should review the output of
the following debug during a call:
debug ppp negotiate
debug aaa authenticate
debug aaa authorize
debug ip peer
195
