03-04-2003 05:12 AM - edited 03-02-2019 05:33 AM
I need to set up/down a router interface via script to be scheduled.
Is it possible through SNMP ?
Can anyone give me the correct MIB path to do the task ?
03-09-2003 08:21 AM
Not sure if it is possible trough snmp. your script would just issue the shutdown or no shutdown command for that interface. Solarwinds has a great mib brouser and mib walk utilitys. you can download it from tucows as a 30 day evaluation copy.
hope this helps
gene
03-09-2003 08:50 AM
Yes, you can turn an interface up/down using SNMP. To administer an interface down simply set the value of:
interfaces.ifTable.ifEntry.ifAdminStatus.N to integer value 2.
To turn interface Up, set it to value 1. Note N above is the number associated with the interface you are trying to control.
Hope this helps
Thanks.
03-09-2003 11:43 PM
Do you know of any snmp utility ( windows ) to do the task ?
thanks again
Stefano
