Community Member
setting duplex setting on a Cat-2950
I am trying to set the duplex setting to "auto" on a port on Cat-2950 switch. The port speed is 100. I am using CLI and getting an error message that a port duplex could only be set to "half" or "full". Yet, the doc states that the "auto" is an allowable setting.
Has anyone come across this problem?
thanks.
Community Member
Re: setting duplex setting on a Cat-2950
Sorry,that was supposed to be Cat-2980G not Cat-2950.
Purple
You can't hardcode the speed to 100 and set the duplex to auto , it has to be either auto/auto or 100/full or 100/half hardcoded . Also remember to exactly match whatever is going to be on the other end of this interface whether it be a workstation or another switch .
91
