Setting STP Port States
I would like to know if there is a way to set the port state to any of the available states.
Say I want to force a port to be in the Listening mode all the time.
1 ACCEPTED SOLUTION
Re: Setting STP Port States
Hi Friend,
Thats not possile port can either stay in blocking state or fwding state you cannot hold it on listening or learning state as these 2 stages are transition stages for any port.
Yes if any port is malfunctioning it may keep looping in these stages but you will not have a control to make the port stuck into listening or learning stage.Though you can control blocking and fwding stages playing with STP values.
HTH, if yes please rate the post.
Ankur
1 REPLY
Hi Friend,
Ankur
226
