Setting up Port Grouping in a 2900XL Switch Cluster
My question is this..
Should I setup the port-groups on the "command" switch or should I setup up the port-groups on each of the "member" switches? (we have 2 "member's")
Does it matter?
Cisco says since I'm connecting switches I should use the (Default) Forwarding based on Destination-address. Any help?
Thanks.
1 REPLY
Re: Setting up Port Grouping in a 2900XL Switch Cluster
It’s hard to say without seeing your topology, but I would follow Cisco’s advice. Here are some documents you may want to look at:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35xu/scg/kiconfig.htm
97
