setting up username and privelege on 2900M XL
When setting up a username, privelege and password on a 2900, I would expect to see the initial username: prompt @ line con 0 but I don't? Instead, I see my line con 0 password: prompt and then I have to type in login, at this point I see the username: prompt. Is this the correct sequence of events for setting up username logins or am I setting it up wrong? Any help please!
~zo
Silver
Re: setting up username and privelege on 2900M XL
can you paste in the config of con 0
line con 0
transport input none
stopbits 1
line vty 0 1
password {omited}
login
Silver
you may have to add the line
login authentication local
make sure you have 2 sessions open in (conf-line) when you do this in case you lock yourself out
102
