sfm2 module on c6k
Sir,
I have 2 questions about SFM module on C6k.
I got some error message on C6k:
*Jan 26 20:06:21: %ONLINE-SP-6-INITFAIL: Module 3: Failed to synchronize Port asic
*Jan 26 20:06:21: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (env-related reason)
I have no idea about it.
2 How can I find the serial number of the module "WS-X6500-SFM2". I got a s/n from 'show module' command but it's invalid in cisco parts database.
Any help would be appreciated!
Thank you very much!
Sha
Re: sfm2 module on c6k
s- Serial numbers are on the physical component. If you slide the card out of the chassis about 3 inches, you should see a yellow sticker with a combination of letters and numbers on it. You may see several, but I believe the serial number for the card is usually on the left side. I record all serial numbers for these cards prior to installation so that I have it if/when needed. Let me know if this helps...
-Bo
Dear Bo,
As I can see the module, I will forward your suggestion to my customer. I think he would find the serial number.
Sha
264
