Community Member
SFP module not showing up as interface choice
I am trying to configure a 3825 router w/IOS 12.4(3d).
When I install a GLC-SX-MM module, I cannot see the module in the sh diag results and therefore not a choice in the list of interfaces.
When I view the logs, the insertion is logged.
Any assistance would be greatly appreciated,
Re: SFP module not showing up as interface choice
Sounds like a code or feature set problem . i would check to see what code you need to support this module. Code level looks high enough but may not be correct feature set , also need at least 256 meg of dram to support this card in your router...
Community Member
Hi Chris,
There are two Gigabit Ethernet ports on Cisco 3800 Series systems. Port 1 is a fixed 10/100/1000BASE-T RJ-45. Port 0 can choose between 10/100/1000BASE-T RJ-45 and an SFP module slot. SFP modules are optional.
A new command-line interface (CLI) allows you to choose between the two media types. The "SFP" option will only come up if there is a SFP module plugged into the slot. RJ-45 is the default.
Please see the following configurations to get this port working:
Cisco3825#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Cisco3825(config)#interface gigabitEthernet 0/0
Cisco3825(config-if)#media-type ?
rj45 Use RJ45 connector
sfp Use SFP connector
Cisco3825(config-if)#media-type sfp
After this you should be able to use and see the SFP on the router. Hope this helps. :)
