sharing NM24DM with two NM E1 and 2 ip pools
hi all
I've a C3640 with 1 NM 24 mica modem and 2 E1 configured as pri (with 2 phone n°)
i want to perform ppp cback,ppp authe chap , work with a ip pool p1 with the first E1
i don't want to perform cback, ppp authent,and work with a ip pool p2 for the second.
here is a piece of conf (incomplete it's just to explain)
control E1 0/0
pri-group timeslot 1 31
control E1 1/0
int group-async 1
peer def ip add pool p1
ppp callback accept
ppp authent chap callin
group-range 97 108
int group-async 2
peer def ip add pool p2
group range 109 120
line 97 108
modem inout
login local
transport input all
autoselect during login
line 109 120
modem inout
The pb is that the 3640 assign async port in an increasing way so after 12 connections on the first phone n° the port is 109 and the ip pool becomes p2
and i've ppp authen problems.
how can i force incoming calls on a PRI to use only a specific range of 1async
ports and no more? a sample conf would be useful
Thanks a lot
1 REPLY
Re: sharing NM24DM with two NM E1 and 2 ip pools
Unfortunately on 3600 paltforms, The feature you are looking for (modem pooling) is not available on 3600 platform..Means there is no way to direct incoming calls to specific or group of specific modems..so 3600 will pick the modem for incoming call on round robin fashion..
On 5300 onwards platforms, modem pooling or resource pooling based on dnis or so is available so that you can use specific group of modems based on the number dialed to terminate the calls.
110
