Should an ISDN Primary Rate port adapter be recognised when installed in a 7206VXR
The 7206VXR does not recognise the Primary Rate port adapter and the controller E1 command cannot be issued. The router has an NPE400 installed and is running 12.1(6)E. Is this an invalid hardware/software combination, if so what level of IOS should be used?
  • Other Network Infrastructure Subjects
1 REPLY
Anonymous
N/A
Re: Should an ISDN Primary Rate port adapter be recognised when
These are the following which are not
supported:
PA-CT1/PRI
PA-CE1/PRI-75
PA-CE1/PRI-120
The reason for this is described here:
http://www.cisco.com/warp/public/770/fn3028.shtml
73
