Show interface Serial question
Does somebody have a clue what the "Available Bandwidth" line in the show interface output below means ? Find the "sh run" of this specific interface below as well.
router#sh int s0
Serial0 is up, line protocol is up
Hardware is MK5025
Internet address is xxxx
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
reliability 255/255, txload 28/255, rxload 22/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:23:05
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/74/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1536 kilobits/sec
5 minute input rate 177000 bits/sec, 139 packets/sec
5 minute output rate 232000 bits/sec, 152 packets/sec
224217 packets input, 37116335 bytes, 0 no buffer
Received 163 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
246051 packets output, 54419398 bytes, 0 underruns
0 carrier transitions
#sh run int s0
Building configuration...
Current configuration : 220 bytes
interface Serial0
bandwidth 2048
ip address xxxx
ip accounting output-packets
ip pim sparse-mode
no ip mroute-cache
compress stac
1 REPLY
Re: Show interface Serial question
This value is the amount of the bandwidth that can be assigned to user data (means out of layer-2/3 control traffic) in case you use CBWFQ queueing mechanism on this interface (75% of the interface bandwidth) but I see that there's no configured service-policy for this interface and therefore it doesn't affect you.
Regards.
211
