Community Member
show process cpu - adjust regions
I have in the output from the command show process cpu the following process: adjust regions. The output shows a high utilization of CPU for this process. What this process means? This process exists on the L3 switches. Thank you
Roman
Community Member
Re: show process cpu - adjust regions
Hi.
Can you give me output from the show process cpu ??
thanks
Community Member
Hi here is:
sim#sh processes cpu
CPU utilization for five seconds: 23%/2%; one minute: 20%; five minutes: 19%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 45 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 1727 91073 18 0.00% 0.00% 0.00% 0 Load Meter
3 97526 1056283 92 0.00% 0.00% 0.00% 0 OSPF Hello
4 970250 62236 15589 0.00% 0.14% 0.15% 0 Check heaps
5 26 41 634 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 1337722 3060191 437 0.42% 0.33% 0.30% 0 ARP Input
8 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
9 0 2 0 0.00% 0.00% 0.00% 0 AAA high-capacit
10 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
11 302 14 21571 0.00% 0.00% 0.00% 0 Entity MIB API
12 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage
13 16 7668 2 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
14 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
15 11196 413321 27 0.00% 0.00% 0.00% 0 IPC Periodic Tim
16 9585 413321 23 0.00% 0.00% 0.00% 0 IPC Deferred Por
17 281 30603 9 0.00% 0.00% 0.00% 0 IPC Seat Manager
18 51955 106062 489 0.00% 0.02% 0.00% 0 HC Counter Timer
19 52991 77111 687 0.00% 0.00% 0.00% 0 Collection proce
20 21313 413315 51 0.00% 0.00% 0.00% 0 Dynamic ARP Insp
21 0 1 0 0.00% 0.00% 0.00% 0 ARP Snoop
22 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client
23 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
24 13477 67723 199 0.00% 0.00% 0.00% 0 Net Background
25 78 686 113 0.00% 0.00% 0.00% 0 Logger
26 24857 413270 60 0.00% 0.00% 0.00% 0 TTY Background
27 54654 413462 132 0.00% 0.00% 0.00% 0 Per-Second Jobs
28 126719 8039 15763 0.00% 0.01% 0.00% 0 Per-minute Jobs
29 0 21 0 0.00% 0.00% 0.00% 0 AggMgr Process
30 33216 1049698 31 0.00% 0.00% 0.00% 0 Net Input
31 247833 85547 2897 0.00% 0.02% 0.02% 0 Compute load avg
32 2403 8155913 0 0.00% 0.00% 0.00% 0 DownWhenLooped
33 0 1 0 0.00% 0.00% 0.00% 0 HRPC hdwl reques
34 0 1 0 0.00% 0.00% 0.00% 0 HRPC lpip reques
35 0 2 0 0.00% 0.00% 0.00% 0 HLPIP Sync Proce
36 0 1 0 0.00% 0.00% 0.00% 0 HRPC Multi-FS Sy
37 0 36 0 0.00% 0.00% 0.00% 0 HULC multifs pro
38 0 2 0 0.00% 0.00% 0.00% 0 MIRAGE RBCP Moni
39 0 1 0 0.00% 0.00% 0.00% 0 HRPC asic-stats
40 0 1 0 0.00% 0.00% 0.00% 0 HRPC hsm request
41 0 7 0 0.00% 0.00% 0.00% 0 Stack Mgr
42 150 6 25000 0.00% 0.00% 0.00% 0 Stack Mgr Notifi
43 225536 21749012 10 0.00% 0.01% 0.00% 0 Fifo Error Detec
44 47649987 99158 480575 13.58% 9.53% 8.91% 0 Adjust Regions
45 34110 413280 82 0.00% 0.00% 0.00% 0 hrpc -> response
1561
