shutting down a atm interface configured in a pvc range
jthreadgill
I need to temporarily disable a atm interface configured in a pvc range. The need for this is to suspend a customer for non pay without going out to the remote cabnet and pulling wires. The problem I am having is you can't get into the interface if it is configured in a range. If you have any other suggestions I could try that would be great. They are on a DHCP range and we are not using PPPOE, so denying IP's or user names wont work.
Thanks for the help,
JT
anup.anand
Level 5
Level 5
Check this links which talks about configuring and deactivating an individual pvc within a range, hope that helps.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a008008039b.html#1020780
Anup
That is what I needed. I don't know why I couldn't find it.
Thanks for the help Anup,
JT
