Webcast-Catalyst9k
Simple RIP2 question
I am trying to route two unmanaged switches with a default RIP install:
interface FastEthernet0/0
ip address 192.168.0.2 255.255.255.0
speed auto
full-duplex
interface FastEthernet0/1
speed auto
full-duplex
router rip
version 2
redistribute connected
network 192.168.0.0
network 192.168.1.0
ip classless
ip http server
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
C 192.168.0.0/24 is directly connected, FastEthernet0/0
C 192.168.1.0/24 is directly connected, FastEthernet0/1
R* 0.0.0.0/0 [120/1] via 192.168.0.1, 00:00:05, FastEthernet0/0
I have a pix and I simply turned on rip v2 on the inside interface...
The behavior I am getting on this setup is pretty strange.
I can ping a host on the 192.168.1.0 network from a host on the 192.168.0.0 network, and even remote desktop into it...but I can't ping anything from the other side...other then the interface addreses on the router and the machine I remoted from...
any ideas? I am I missing something on my config probably?
VIP Purple
Re: Simple RIP2 question
how is the PIX physically connected ? Is this config from one router with two FastEthernet interfaces ?
I would check if the ping might be blocked on the PIX.
GP
I was just being silly, the unpingable hosts werent pointing at the router as a default gateway...
as soon as I set the default gateway properly, it of course works...
I need more coffee...
=P
69
